This is a GE WHDSR109J5WW washer that is less than 2 years old. It will spin and aggitate when empty but will not spin after running a load of clothes. I have replaced the switch, it was broken before, but this problem still exists. I am thinking it could be the transmission, haven't heard any unusual noise from the machine though. Any thoughts would be appreciated.
Jeff
Put in a full load and operate it with the front panel off. This will tell you if the motor is turning but the basket is not, or if the motor is not turning.
