jamie_pancake@yahoo.com
#1 Posted : Tuesday, March 6, 2012 11:15:25 AM(UTC)
This WP dishwasher has blown 3 fuses on the circuit board. I have replaced the thermister and the thermal cut off to the heater. What is the solution?:confused:
Joe / APP Team
#2 Posted : Tuesday, March 6, 2012 11:51:23 AM(UTC)
Joe / APP Team
Jamie,
This is the "kit" you're installing Part number: AP4423189
and we're refferring to, correct? You are installing all of the parts, including the wires and following all instructions "to the tee".
You will also need to check the connections and voltage at the junction box wires, the heater element and the limit thermostat. You'll also need to check the voltage when the dishwasher is running(under a load) and have to have at the least 110 VAC. and no more than a 9 amp draw on the wiring with the motor running or the heater on.
Thanks and Good Luck,
