Stevr35
#1 Posted : 16 years ago
Stevr35
My Frigidaire Range is flashing a F30 error code when you try to use the oven. the cook top still works as it should. From the error code list it say to check the Oven temperture probe and OHM it out. Mine checks 1091 @ 74 degrees just as the spec calls for. What should i check next?
kayakcrzy
#2 Posted : 16 years ago
kayakcrzy
Originally Posted by: stevr35 Go to Quoted Post
my frigidaire range is flashing a f30 error code when you try to use the oven. the cook top still works as it should. from the error code list it say to check the oven temperture probe and ohm it out. mine checks 1091 @ 74 degrees just as the spec calls for. what should i check next?
that is a good reading, but sometimes it checks to be good when it is not. i read the code also, and it says replace sensor probe. but, the sensor probe plugs into the erc board, and that is where the problem could be. so my friend it is a toss up. you could replace the sensor, and see if it works. if not, the board will be the issue. that is the best way to approach it. when a erc board is bad, i usually sell the sensor also. its just a good way to go, because, sometimes a bad board could damage a sensor. tom
