Need help replacing Control panel P.N. AP3890830 Control panel on Whirlpool Dryer. How do you take the plastic cover off to get to control panel and is this panel a plug in module?
I have ordered but not received yet.
Thanks for help
I have not been into the top of that particular model, but if you take the top cover off by removing the screws in back it should get you access to the control panel.
You should also find some tech notes which should help you do the job.
Good luck.
