had a estimate,said i need a new inlet valve assembly,drain pump & motor drive coupler,repaced all, and machine will still not fill with water.
Originally Posted by: rambo2 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) had a estimate,said i need a new inlet valve assembly,drain pump & motor drive coupler,repaced all, and machine will still not fill with water. Hello Rambo. Here is the switch that you need Part number: AP4459660
this is a sensor switch, that lets the water come in replace this and your unit will fill, Thank you and good luck !
