When I shut the door to my microwave, it starts running on its own. It emits no heat, although the turntable, light, and fan work. It only stops running when the door is open. Is there a part I can replace to fix this?
-Timissa
Originally Posted by: timissa ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) When I shut the door to my microwave, it starts running on its own. It emits no heat, although the turntable, light, and fan work. It only stops running when the door is open. Is there a part I can replace to fix this?
-Timissa Timissa, You most likely have a faulty door switch or wire. Unfortunately, your model number has little to no parts or service information. " Return To Vendor Model List " You will need to contact the dealer where you purchased the unit and have them direct or assist you, to receive parts and service information for your microwave. Thanks and good Luck, :) :) :)
