Machine runs fine empty. Under moderate load, does not spin. If I pull out the wet clothes and run the spin cycle it seems fine. I can then add the wet clothes a bit at a time, and the spin cycle will complete. Clutch? I have replaced the coupler, which did not help. Thanks in advance.
I would replace the clutch as it is likely your problem. On the way to do it you can inspect the drive block, and if it is ok go ahead and put in the new clutch assembly.
Good luck.
I will do as you suggest. Thank you very much.
Originally Posted by: sidfink43  I would replace the clutch as it is likely your problem. On the way to do it you can inspect the drive block, and if it is ok go ahead and put in the new clutch assembly.
Good luck. Clutch solved the spin problem. Thank you. Here's another. It wants to overfill now. When I was re-assembling, a gold colored pin seemed to fall out of something, but I wasn't sure if it was part of the machine. I guess it was. It has a hole in the end, I guess for a cotter type pin...
That holds the suspension parts in place. There should be a plastic cover over it. Look under the machine and you will see another one just like it, so line up this one and see if you can fit it back it.
If you cannot try the machine without it, you might be ok.
Good luck.
Originally Posted by: sidfink43  That holds the suspension parts in place. There should be a plastic cover over it. Look under the machine and you will see another one just like it, so line up this one and see if you can fit it back it.
Good luck. Thanks. Probably why I'm getting a metal on metal sound when it spins as the suspension is not balanced. I will fix that. What could I have done to cause the washer to over fill? Just wants to keep filling no matter what level I have it set at!
You problably knocked the plastic tube from the water pressure switch to the tub off. Check to see that it is connected at both the switch and tub ends.
If not and the problem continues, see if the water stops entering when you stop the machine. If not, replace the valves, if it does and the plastic tube is ok the water level pressure switch is not working.
Good luck, I am betting fixing the tub will fix it.
That thought came to me as I was floating in my pool trying to get the sweat off me from first 2 hours of washer fun! Probably would have helped if I had put the spanner nut back on too. Sheesh.
Originally Posted by: sidfink43  You problably knocked the plastic tube from the water pressure switch to the tub off. Check to see that it is connected at both the switch and tub ends.
Good luck, I am betting fixing the tub will fix it. That took care of it. Thanks so much for all your help. After taking the whole thing apart and cleaning it, I will never use the automatic softener dispenser again. UGH!
Yeah, the general rule is if you have parts left over that is not a good thing.
Well, it has been hard but think of all you have learned. Brag to your friends, (but not the ones who will expect you to fix their machines)
