Hello,
My Admiral washer has recently began to agitate during the spin cycles. What is the cause?
Thank You
This is usually a transmission issue.
Originally Posted by: sidfink43  This is usually a transmission issue. But it turns freely on the drivebelt and has no fluid leaking from the tranadmission seal.and then locks up after it makes a rubber on metal squeaking noise.
