Suddenly my refridgerator stopped running. The light is on when opening the door(there is power to it) but the compressor will not turn on. Thanks for any solutions. Jork
Turn the cold control off and on,if it clicks, it's probably ok. Look under the control panel and use a flat blade screwdriver and turn the defrost control. If it now runs, replace the control.
