My oven is not igniting. I can hear the (and then smell) the gas valve opening but the buzz of the ignitor is absent. I've uncovered the burner and spark electrode, everything looks fine. I assume there is an a spark module which is the culprit. Is there anything else I should be looking at? Can anyone tell me the appropriate part number.
Thanks in advance
Same problem here. I went one step further, took the spark ignitor out, and measured the volts AC from the ignitor lead to ground and it measured 100 VAC. Did replacing the ignitor fix your problem? Or did you have to fix a one or more boards?
