GE Eterna Triton XL edw4060g02ss
I read around the forum and did some diagnosing. The only thing it is not doing is putting water into the tub. If I manually put water in and start the cycle it works fine, so door switch, drain all are okay. Water valve is alright. The pipe does change temperature, so the water is at least flowing from the valve under the sink. Also read somewhere the pump might simply be stuck, but without knowing how to get it apart, I don't want to go sticking my hand in places. Float bowl switch moves up and down fine. It might actually be the electric part of the float bowl switch that's bad, but I don't know how to get to it. Don't want to start taking random things apart. Any help is appreciated.
