ACE007
#1 Posted : Saturday, August 1, 2009 7:33:26 AM(UTC)
ACE007
Is this a tough job? Does it require special tools?
sidfink43
#2 Posted : Monday, August 3, 2009 9:02:45 AM(UTC)
sidfink43
See if what you are trying to do is described in this tech bulletin.
http://www.servicematters.com/m...rary/docs/TDL-0086-B.pdf
If the answer is yes, then it is a fairly intensive job and will require special tools.
