How doyou remove the Coupler on the turn table to install the new one, the part number for the coupler is WB06X10420. The turn table stopped rotating and I ordered this part to replace the old one. The motor runs and turns but the Glass would not rotate.
How do you remove the old coupler to the turn table? I ordered the new part, coupler part number WB06X0420 and need to replace the old one with the new part?
How do you remove the old coupler on the microwave turntable. I ordered the new part and need to remove the old part so I can install the new coupler part number WAB06X10420? Thanks.
