I have discovered a leak in the water tank of a 10 year old GE frig, model # below. I would like to replace it with the part # below but do not know where the two tubes go...they just 'vanish' inside the body of the frig & I've no doc or diagram to go on. Thanks for any help!!
Model # off refrigerator: TFX25PRYD BB Water Tank part # : AP2066390
Just cut the old tubes keeping them long enough to connect the tubes from the new water tank, using a plug in water line connectors. I'm not sure what is the size of these tubes. You can use a 1/4" or 5/16" connectors depends on the tube size in the water tank. - The 1/4" connector Part number: AP3085805
