I have a Frigidaire dryer, (FDE216RES1) and the main back shaft (ballhitch) broke a few weeks back, stoping the dryer. I replaced that, and noticed that the Coil electric dryer had broke and shorted out to ground. I replaced that. Still no heat, so I read some on the web and got out my Ohms meter and checked the Thermostat , Thermal limiter ,and T - stat, reg - heat for any shorts, and they all tested full electrical continuity. I noticed that on the timer the Resistor, power showed braking in the shilding, so I replaced that. But the old one tested the same as the new one I bought. Why is this dryer not working? Please help me before my wife makes me buy a new one!
Originally Posted by: scott burchett I have a Frigidaire dryer, (FDE216RES1) and the main back shaft (ballhitch) broke a few weeks back, stoping the dryer. I replaced that, and noticed that the Coil electric dryer had broke and shorted out to ground. I replaced that. Still no heat, so I read some on the web and got out my Ohms meter and checked the Thermostat , Thermal limiter ,and T - stat, reg - heat for any shorts, and they all tested full electrical continuity. I noticed that on the timer the Resistor, power showed braking in the shilding, so I replaced that. But the old one tested the same as the new one I bought. Why is this dryer not working? Please help me before my wife makes me buy a new one! FIXED. dam fuse blew on the cut off sw.
Glad to hear you were able to fix it. Good job.
Thank you for the feed back and good luck with your dryer.
