navke01
#1 Posted : Thursday, July 30, 2009 5:27:33 PM(UTC)
navke01
After starting a cycle first the SUD caode appears on LED display and then F35. It appears to be realted to the pressure switch. I disconnected the hose from the switch and blew in to see if it was clogged. It did not appear to be. Still have same problem. Would like any other thoughts or help ordering the part form my washer. Thanks.
sidfink43
#2 Posted : Sunday, August 2, 2009 6:48:23 AM(UTC)
sidfink43
Take off the bottom panel and
1. Clean out the drain/pump area and make sure there are no obstructions in the drain.
2. You should find tech notes that will take you through a trouble shooting routine and tell you what the error code means.
Good luck.
navke01
#3 Posted : Sunday, August 2, 2009 12:03:19 PM(UTC)
navke01
Thanks. I see there are 2 clamps on pump. One from tub, one to drain. I guess I should take off both and check.
I tried to order pressure switch, but they are on back order evertwhere. Makes me think they are faulty.
Thanks Again.
