cookie 88
#1 Posted : Thursday, July 30, 2009 1:24:04 PM(UTC)
cookie 88
The timer wires are disconnected. I don't know which color wire goes where. The diagram that was given to a guy with the same problem. I have the same diagram attached to the dryer but i can't understand the black and white writting. It was not helpful at all. iam hoping some one can send a coler diagram showing which color goes where or explain to me which color goes where. your help would be greatly appreciated. :confused: :confused: :confused:
sidfink43
#2 Posted : Friday, July 31, 2009 5:05:54 PM(UTC)
sidfink43
Hi Cookie
I don't know how to get you a color diagram, but here is the wiring diagram from the Frigidaire site with the color of the wires designated.
http://manuals.frigidaire.com/p...df/Webster/131953900.pdf
If you cannot determine the connections from this I suggest you contact Frigidaire customer service and see if they can help. The company is pretty user friendly so you should get some support.
Good luck
