slb696
#1 Posted : Wednesday, July 29, 2009 4:47:05 PM(UTC)
slb696
Does the belt need replacing? Can it be easily replaced?:confused:
sidfink43
#2 Posted : Friday, July 31, 2009 10:35:51 AM(UTC)
sidfink43
It is possible but very unusual for the belt to be the source of the noise. More likely it is the rear rollers. Listen and see if you can locate where the noise is coming from. If you need to, take off the door, and then the front panel and reattach the door and operate the machine.
Here are the rollers and reference to the front bearings.
Part number: AP4008534
