The model number is 36-6554-00/0203835061552 (the last part is the serial number) It is anO'Keefe & Merritt Sculpture (probably at least 20 years old) that needs a new thermostat (since a grease fire destroyed the original). The oven will light, but at "broil" it will only heat to about 200 degrees. It's a great 36 inch stove but I am afraid that the part to repair it are no longer available. Any ideas on how I might locate the part?
In order to provide the most accurate advise I need the complete model number of the unit or the part number written on the old thermostat.
