I have a frigidaire dryer fse447ghs0 and clothes are getting caught in drum. after researching I ordered from you the following.
Part Number Description Qty Price ------------------------------------------------------------------------------- AP2150497 (5303937139) Felt glide assembly 1 $22.20 AP2143044 (5303283286) Seal/basket lower 1 $19.59
Can you provide instructions for installing these parts.
Thanks Tom
Tom, You have to remove the top panel first and then the front panel. Remove the old felts and clean the metal surfaces from the old particles. Install both new felts using the glue included in the felt/glide assembly. Let it dry before reassembly. Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FSE447GHS0 | AppliancePartsPros.comGene.
How long does it take for the glue to dry before reassembly, and how long should i wait unit i can use the dryer
thanks tom
I believe 2-3 hours should be enough before you can assemble it back. I would wait a day before use it again.
