freezer icing up lower part of frig not cooling properly. already replaced defrost timer
freezer icing up lower part of frig not cooling properly:confused:
Remove the back freezer panel and check for total frost, or partial frost. If total,heavy frost, most probably a bad defrost thermostat clipped to the evaporator.
