Ok, so my dryer doesn't work... It will turn on, and make all the noises but won't actually spin. all the click's are there and everything. combined that with I tested with 2 different meters for ohm's, and NOTHING. anything else i can check? is the motor gone?
No one has an idea? or is it that obvious that i am just dumb?
It was the motor. just FYI..
so if everything acts exactly normal, but it doesn't turn, it's the motor.. just so you all know now that I've figured it out myself.
