The water is leaking from the side of the plastic piece where the fill hose attaches on the left side of the tub. There is an opening on each side of the plastic piece and the leak comes from the left side. How would I fix the leak? Thanks.
Nevermind. I reamed out the fill hole with some wire and a lot of crud came out. Reattached the hose and and the leak stopped.
