wolfpack
#1 Posted : Monday, July 27, 2009 8:58:57 AM(UTC)
wolfpack
My dryer quit heating and read that it could be the heating elelment or a fuse. I found the heating element but I can't figure out where the fuse is.
Help!
Bothcoasts Handyman
#2 Posted : Monday, July 27, 2009 9:49:21 AM(UTC)
Bothcoasts Handyman
Hello,
If you lift the cover/top of the dryer up. (it will pop up held in my snap type holders) there should be a wiring diagram in there.
You can start from the element and trace the wires back to where it goes into the electronic panel. The fuse should be in this line. (make sure it is unplugged).
The easy way would be to test for power or continuity from the panel to the element.
Let me know if you find anything in the top of dryer as far as paper work that might show the fuse.
