My oven and broiler will not work at all. The display and all 4 burners still work. I can turn the oven on and set it and the preheat light comes on, but nothing even gets warm (the broiler dosent work either). When the preheat light is on on you can hear clicking like it is trying to work.:confused: Oh the self cleaning latch is in the correct position.
Most likely the problem is a bad control board. It has to be replaced together with the overlay because it's glued to the control board. - The control board Part number: AP3993776
