billlaurie7
#1 Posted : Monday, February 20, 2012 2:20:30 PM(UTC)
billlaurie7
My refrigerator is awful noisy. I pulled the refrigerator off the wall, took the back cardboard off and saw that the cooling fan is hitting the housing. This is the fan underneath the freezer in the back bottom. What part should I order to fix? Is this easy to repair?
ApplianceJunk
#2 Posted : Monday, February 20, 2012 2:36:22 PM(UTC)
ApplianceJunk
Can you just adjust it so the blade does not hit?
billlaurie7
#3 Posted : Monday, February 20, 2012 2:55:55 PM(UTC)
billlaurie7
Tried to adjust the fan up a little but the blade was so loose that it did not make much difference. Either is a vibrating noise or hitting something.
