joyce stilson
#1 Posted : Monday, February 20, 2012 11:34:50 AM(UTC)
joyce stilson
Dishwasher works ok but will not drain completly. It leaves abount a 1" of water in the bottom. Drain line is ok. What ya think??
ApplianceJunk
#2 Posted : Monday, February 20, 2012 12:19:04 PM(UTC)
ApplianceJunk
It's been my experience that if it's pumping water at all, but not getting it drained all the way it's because of some kind of restriction.
joyce stilson
#3 Posted : Monday, February 20, 2012 12:27:15 PM(UTC)
joyce stilson
Thx. I have cleaned the garbage disposal hose out. Where elese would you suggest I look for blockage and how would be the best way to get to it??
joyce stilson
#4 Posted : Tuesday, February 21, 2012 6:28:09 AM(UTC)
joyce stilson
can I put draincleaner in the washer and run the drain cycle?? Or should I pull the washer out and and clean out the hose and washer? Can this be done without taking the washer appart?? Thx.
ApplianceJunk
#5 Posted : Tuesday, February 21, 2012 6:32:00 AM(UTC)
ApplianceJunk
I would not use drain cleaner.
joyce stilson
#6 Posted : Tuesday, February 21, 2012 1:38:01 PM(UTC)
joyce stilson
OK Should I pull it out??
