RickP
#1 Posted : Saturday, January 5, 2008 12:20:40 PM(UTC)
RickP
I have a kenmore elec dryer bought mid 90's from what I have read I think I have a bad motor, (runs a while, has a rumble like sound from the motor area then shuts off - it had been squeaking a little also, when taken apart if you spin the motor with belt off you hear a litttle metalic squeak in one area while it turns by hand. How do i get the old motor out? one end drives the belt, the other goes into the blower fan and the fan has a square hole in the middle of the shaft?
a219dan
#2 Posted : Saturday, April 18, 2009 6:42:24 AM(UTC)
a219dan
i too have a dryer that runs for a while then shuts off. if you try to restart the unit the motoe just hums and if to many attempts are made the motor doesnt even hum. what gives ?
JoeG
#3 Posted : Saturday, April 18, 2009 9:04:10 AM(UTC)
JoeG
My motor is gone and I have the front bottom panel off. I am trying to figure out how to disconnect and replace the motor as well. I already bought the motor for $128.
Kenmore elec dryer beeps and stops (Dryer Repair)
by j michael 51 8/31/2013 1:36:20 PM(UTC)
Kenmore Elec Dryer not running on air dry/no heat on all cycles (Dryer Repair)
by jmm53 5/9/2013 11:32:08 AM(UTC)
Intermittent heater op on Kenmore elec dryer (Dryer Repair)
by soonerdaev 2/13/2010 9:27:01 AM(UTC)
Kenmore elec dryer motor (Dryer Repair)
by timclayton 10/13/2009 4:06:13 PM(UTC)
by omsrof 4/16/2009 6:18:20 PM(UTC)
