I have a Kenmore 800 series dryer that shuts of about a 1/3 of the way through the automatic dry cycle. If I rotate the dial manually it "clicks" in the spot where it turns off. It's the same "click" it makes when you normally pass an off position. I tried running it in the timed cycle and it won't start at all. The only position it will start in is the "more dry" position, but then turns off too soon like I said earlier. Am I safe to assume it seems to be a timer issue? Thanks!!
Anyone? Hate to throw $95 at it without having a little feedback.
