How difficult is the installation of a Motor Control Assembly (Part #AP4027228 in a Maytag Neptune Front Load Washer? It is showing an error code of LR & I am told that is the part that is needed. It does'nt completely fill/empty & I don't think it is spinning.
Hi Donna What you want to do is fairly easy, just take off the door, then the other two screws holding the front panel on and remove it. This will give you access to the motor control board. Here is the service manual which will show you how in detail. Your model is an updated version of the basic Neptune 3000. http://www.servicematters.com/m...ibrary/docs/16010061.pdfThe supplement at the back is an update for your model. See page 4-5 for details on how to remove the board. Also, I suggest you do as much of the testing/troubleshooting as you can from the supplement to try to make certain the part you are replacing is the right fix, as it is pretty expensive. Good luck.
