megtom
#1 Posted : 16 years ago
megtom
The microwave part of our oven/micro combo built in would not shut off last night. It came on by itself after we had used it for dinner and stayed on even if you opened the door. Is this something that can be fixed and if not is there somewhere to purchase only a microwave that will hook into the space?
megtom
#2 Posted : 16 years ago
megtom
The comtrol pad was also blank not accepting any kind of commands. Any info? I'd rather not have to sink $2k into a wall unit right now.
#3 Posted : 16 years ago
Most likely the problem is a bad control board. Unfortunately this part has been discontinued by the manufacturer.
Here are the breakdown diagrams and Replacement parts for GE JKP65WP2WG | AppliancePartsPros.com
jacksokla@aol.com
#4 Posted : 16 years ago
jacksokla@aol.com
I don't think my message is getting to you. I will try again. I have a built in microwave #rvm255bloz. the clock is lit up but the buttons don not do anything when you press them. Can u help?:eek: Thanks
#5 Posted : 16 years ago
Most likely the problem is a bad key panel. The black key panel has been discontinued by the manufacturer. The white key panel is available, but it is on back order.
- The white key panel assembly Part number: AP2025864
Here are the breakdown diagrams and Replacement parts for GE RVM225BL02 | AppliancePartsPros.com
