JeffAlwine
#1 Posted : Saturday, July 25, 2009 5:39:18 PM(UTC)
JeffAlwine
Clothes are coming out of the washer still dripping with water. I have verified that there is no clog in the drain hose and that the "Agitate/Spin setting is set to normal (slow/fast). The switch clicks when I push in on it, what else should I be checking? Thank you.......Jeff
sidfink43
#2 Posted : Monday, July 27, 2009 6:10:29 AM(UTC)
sidfink43
Hi Jeff
Open it up and take off the pump and check it out. Make sure it is not clogged or broken and is operating correctly.
If your machine is spinning at the right speed and there is no problem with the pump/drain system the clothes have to spin semi dry
If you need more info please post your full model number and the results of your pump inspection.
Good luck
