Hello friends Serial No SGS45E68GB/64 I have no water going in my dishwasher however as I am an engineer I put a multimeter on the inlet valve coil I found no power to the coil. I then checked to see if it had any power pos or neg I found it had 220 volts live phase to coil but no negative. I traced wiring up to the controller on the front of the dishwasher but seems it lost its negative from the controller. As I have no electric schematic or trouble shooting manual is there anything that can cause the controller to lose its negative. Or can someone help to supply me the manuals or schematic Thank you for any help. Paul
Originally Posted by: tallerpaul007  Hello friends Serial No SGS45E68GB/64 I have no water going in my dishwasher however as I am an engineer I put a multimeter on the inlet valve coil I found no power to the coil. I then checked to see if it had any power pos or neg I found it had 220 volts live phase to coil but no negative. I traced wiring up to the controller on the front of the dishwasher but seems it lost its negative from the controller. As I have no electric schematic or trouble shooting manual is there anything that can cause the controller to lose its negative. Or can someone help to supply me the manuals or schematic Thank you for any help. Paul Someone posted a troubleshooting guide for Bosch on the first forum listed titled "dishwasher". It includes electrical schematics
Hi Paul,
Looks like this is the UK model. Unfortunately we do not have any tech information for non American models. I can only guess that the problem is a bad control module.
