How do you replace the module label cover for the water, ice crushed, ice cubes ? Can't find out how to remove the damaged one. Tx for your help poopsie
Usually, they're removed by exposing two or more screws by removing the drip tray. Then the front of the unit generally lifts up and outward to remove. Remember to unplug the machine first.
