I have a GE refrigerator that I suspect the sealed system may have leaked refrigerant. The unit will not cool either the fresh food or freezer compartments. Both fans run (evaporator and condenser), the compressor appears to be running but there is no cooling. I also checked the 3 thermistors @70 degrees F and they read proper resistance. Attached is a picture of the refrigerant lines entering the evaporator, notice the ice buildup on the line. What to you guys think? rohman attached the following image(s):
Any Ideas? am I looking at a new refrigerator or can this one be salvaged?
