sstennis
#1 Posted : Thursday, July 23, 2009 7:44:47 PM(UTC)
sstennis
Hello, we just purchased a used GE electric cooktop and everything works but the heat on all burners. When I turn the knobs, the red light goes on, but not heating??? Any advice would be greatly appreciated.
rslowson
#2 Posted : Monday, August 4, 2014 7:34:08 AM(UTC)
rslowson
I have same issue. GE Model # JP989BK1BB
Would greatly appreciate any assistance. .
#3 Posted : Thursday, August 7, 2014 7:16:40 AM(UTC)
Most likely a power problem.
The indicator lights run off of 120 volts but the elements themselves require the full 240 volts (L1 to L2).
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug. Your unit is probably hard wired so you have to check it at the terminal strip.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
rslowson
#4 Posted : Thursday, August 7, 2014 10:27:10 AM(UTC)
rslowson
If OK
If OK
Thanks. I turned the breaker off then back on and all is well with the universe.
#5 Posted : Thursday, August 7, 2014 11:51:16 PM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
