steve.jas
#1 Posted : Thursday, July 23, 2009 4:29:41 PM(UTC)
steve.jas
I have disassembled the washer to replace the main bearing and Agitator Bell Seal. I have the lubricant for the Bell Drive Seal, what type lubricant should be used on the Transmission Shaft before reassembly?
sidfink43
#2 Posted : Sunday, July 26, 2009 5:46:18 AM(UTC)
sidfink43
Hi Steve
Look on page 29 of the service manual to see if that does not answer your question.
http://www.servicematters.com/m...ary/docs/RS3100007R0.pdf
Good luck, sounds like you are doing what is a hard job very well.
