jeffsuwanee
#1 Posted : Thursday, July 23, 2009 12:26:28 PM(UTC)
jeffsuwanee
Dryer has no heat. Got ohmmeter and checked continuity. High limit fuse checked ok, high limit thermostat checked ok, heating element checked ok, the cycling thermostat did not check out, so I replaced the thermostat with a new one, still did not check out....could it be wiring, or is there a chance that something other than the cycling thermostat is the culprit. I hate to keep spending money replacing the same part, if in fact, something else might be causing the problem.
sidfink43
#2 Posted : Friday, July 24, 2009 6:39:40 AM(UTC)
sidfink43
Hi Jeff
Check to make sure you have 120 volts to each side on the connection block. If that checks out, check your thermal fuse.
If you need more info please post your full model number and the results of the above.
