Scott
#1 Posted : Friday, August 3, 2007 5:33:02 AM(UTC)
Scott
I want to replace the rear bearing above the brake assembly. Can I just unscrew the brake assembly and remove the bearing or will I need a special tool to remove the bearing? Any tips or instructions are welcomed. Thank you.
ApplianceJunk
#2 Posted : Friday, August 3, 2007 4:27:24 PM(UTC)
ApplianceJunk
You should not need anything to remove the bearing.
You will want to get the brake tool to for taking the brake on and off.
#3 Posted : Saturday, August 4, 2007 8:55:01 PM(UTC)
Scott
Here is the complete instructions to remove the bearing http://tinyurl.com/39c9mf (pages 117 through 121)
and the break down diagrams for Maytag washer Model LAT3500AAE
Good luck.
Guest (4)
