steelyk@charter.net
#1 Posted : Wednesday, July 22, 2009 2:00:22 PM(UTC)
steelyk@charter.net
Water dispenser leaks about 20 to 30 drips after water is dispensed. Then drips very slowly. Changed water filter recently and ran 2 to 3 gallons of water through it. I think it might be the water valve (item # 55 on ice dispenser Parts page). I noticed that one time it was dripping the dripping stopped when I heard the ice maker water dispense.
woodchuckie
#2 Posted : Wednesday, July 22, 2009 2:45:31 PM(UTC)
woodchuckie
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. It's a dual valve with the other one supplying the ice maker. It probably jarred the other one completely shut when the valve cut on and off.
