I have an older model ge electric wall oven and the settings or something are messed up. When I turn on the broil setting, it does not heat up, and when I put it on bake only the top element turns on. Help please, i miss my oven :(
Groups: APP Team
Please check if the thermostat and selector switch knobs are not switched around. If this is not the problem provide complete model number of the oven.
Definitely not the switches being backwards. It worked fine one day, then not the next. The model number is J KS06G0J4BG
