Hi
I have a Bosch dishwasher SGV59T03GB/21 in which I just repaired a leak (caused by my own stupidity!) but it will not start up properly to allow me to check. I suspect that the control board needs to be reset. Can anyone tell me how to go about this?
Any suggestions much appreciated
Aidan, Dublin Ireland
You might try reading the "Canceling or Changing a Cycle" instructions in your manual. My dishwasher was stuck in the drain cycle, and it would never start washing. The diagrams in my manual did not match my dishwasher, but I did figure out that if I pressed the "Power Scrub" button and the "Regular" wash button at the same time, it cancelled the drain cycle and allowed me to start the dishwasher again and it now works fine. I suspect that your machine will have a similar solution.
