BoettcherM
#1 Posted : Monday, February 13, 2012 4:00:06 PM(UTC)
BoettcherM
I have a GE HDM1853SJ04. We had a power issue. The power coming into the house had a hot touch the neutral. Many items are not working. This microwave has no indicators or display. No fan or light. Looks just like it is not plugged into the outlet. I did check the fuses on the noise board, there are good. There is 120 volts into the unit. Not sure it is worth repairing. Any help would be appreciated. Thanks.
jorgegv
#2 Posted : Tuesday, May 7, 2013 11:41:40 AM(UTC)
jorgegv
were you able to identify the problem?
I got the same model unit with the same problem.
replaced fuses and did not turn on.
I appreciate it if you provide me with feedback.
thanks
Jorge
