nat1rlw
#1 Posted : Wednesday, July 22, 2009 10:31:03 AM(UTC)
nat1rlw
Oven was put into the self cleaning mode. Since that time the cooling motor will not shut off, the functions: oven, convection oven, and broiler do not work, and the oven door will not open. I have replaced the high temp cutoff switch which did not fix the problem. I have also disconnected the latch unlock and lock switches with no luck. Can you help?
Servicer
#2 Posted : Friday, August 7, 2009 7:48:37 AM(UTC)
Servicer
The unit will stay locked with the fan on if the unit feels the cavity is too hot to unlock the door. This could be a problem with the oven temperature sensor, which is the proble sticking out of the right, rear corner of the oven, or it could be a problem with the plug that connects the sensor onto the relayboard (J10).
KC
