when replacing the lid switch do i also need to replace the wires
Yes, you replace the wires that run from the case to the switch. It will be easier if you remove the case as described on this page Whirlpool Washer Disassembly Guide If your washer is belt driven disregard this post and recheck model number.
everything worked out great. thanks
