outbackblackjack
#1 Posted : Saturday, February 11, 2012 12:56:06 PM(UTC)
outbackblackjack
I have a Roper dryer model REX4634KQ1 that won't stop on auto sense dry. I noticed the auto sense stopped working a little over a year ago. I have taken the dryer apart to clean it thoroughly, I made sure any wires I disconnected I reconnected to where they went by the pictures I took of it while disassembling it. Is a sensor or something else that needs replaced? Any help would be greatly appreciated.
Thanks,
Steve
#2 Posted : Sunday, February 12, 2012 1:38:07 AM(UTC)
Replacement parts for Roper REX4634KQ1 DRYER | AppliancePartsPros.com
The way it works is that:
In timed dry the timer motor gets power directly from the line (240 volts)
In Auto mode the timer gets power through the heating element when the element is shut off by the thermostat.
First I would unplug the unit and set it to auto mid cycle.
Then measures Timer switch 0 contacts TM to OR, they should be 0 ohms.
If OK
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run all the time and the thermostats cannot regulate.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
REX4634.pdf (232kb) downloaded 17 time(s).
Guest (4)
Roper dryer won't stop on auto sense dry. (Dryer Repair)
by outbackblackjack 2/11/2012 11:14:53 AM(UTC)
