mani
#1 Posted : Tuesday, July 21, 2009 6:42:24 PM(UTC)
mani
as i told to replace pressure switch and water inlet valve i replace both but it still give me f/h error message.i check the water line this is also clear.i also change the pressure switch tube what could be with my washer?.tell i see the sensor on the water line close to soap dispencer ,what it does?
sidfink43
#2 Posted : Wednesday, July 22, 2009 4:54:10 PM(UTC)
sidfink43
Hi Mani
I think you are talking about the flow meter, which does exactly what the name implies, it measures the amount of water that flows into the machine.
It is an inexpensive part, and possibly the source of your problem so I would change it out and see if that fixes the problem.
Good luck
whirpool duet show error msg( FH) (Washer Repair)
by mani 7/15/2009 2:21:13 PM(UTC)
