64gears
#1 Posted : Tuesday, July 21, 2009 6:39:02 PM(UTC)
64gears
dishwasher will not drain on final cycle of any setting? It drains fine on every intermediate cycle, however, at end of sequence, tub is full of water. Replaced drain pump (it has power, and continuity) replaced main pump and motor assembly, drain valve assembly, and sequence switch. Only thing left is control board??? PLEASE HELPPPPP!!!!!!
applianceman
#2 Posted : Tuesday, July 21, 2009 7:25:25 PM(UTC)
applianceman
Have you checked the valve flapper #328 on the parts breakdown? It should stop water from flowing back into the pump during pump out.
The piston valve #534 on the parts breakdown can also cause this problem. The rubber stopper should be large enough to stop up the hole in the top of the valve.
[FONT='Times New Roman']Also can you tell if the drain pump is running on the final pump out? If not the control may not be sending power to the pump. Dishwasher Repair Guide[/FONT]
64gears
#3 Posted : Wednesday, July 22, 2009 6:10:34 AM(UTC)
64gears
flapper valve is brand new!!!! only thing I have'nt replaced is the control panel, and ALL wires seem to have continuity. Additionally, drain pump only gets short voltage surge during last 5 seconds of FINAL drain cycle.
applianceman
#4 Posted : Wednesday, July 22, 2009 8:35:02 AM(UTC)
applianceman
Does yours have this part on the side of the main pump? Part Details - GE Solenoid assembly, part number: WD21X10060 If it does make sure the plunger will go up and down in the solenoid freely.
64gears
#5 Posted : Wednesday, July 22, 2009 2:57:09 PM(UTC)
64gears
I am talking about the control board on the front panel!!!!
applianceman
#6 Posted : Wednesday, July 22, 2009 6:51:14 PM(UTC)
applianceman
Ok sorry looking back I see you have already replaced this part. The control board is unlikely but you have replaced just about everything else. Take a look at this part and tell me if you have replaced it or not.
Part Details - GE Piston & nut, part number: WD24X10018
If not try it before you buy the control.
64gears
#7 Posted : Wednesday, July 22, 2009 7:15:46 PM(UTC)
64gears
yes, I have replaced the piston and nut.
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
