The Freezer quit working, froozen meat starting to get thawed.. Fridge side is working properly, lights are working the motor is running, I have cleaned up all the dust on the coil, unplugged the fridge and plug it back up again but ti didn't seem to help... Is there anything I can do to fix the problem? :confused:
Remove the back panel, check the condensing fan, if ok feal the compressor. If running and the thin tubing from it is hot, but the condenser coils are not warm, you have refrigeration problems for a pro to look at.
