Replaced the defrost timer 0.6 ohms across the defrost thermostat (frozen) 22 ohms across the defrost heater Evaporater coil is completely iced up Doesn't make sense to me. Please help
Chas
Turn the defrost timer to defrost and check for defrost action, if none, you may have a bad wire connection in the freezer, or an intermittant defrost thermostat.
